9
How can I avoid the irregularities and stringing in the print. Printer Used: Fortus 450mc
Model: PC
Model tip: T10
Support tip: T12SR
Support: SR-100
Slice Height: 0.0050 in
I have printed two objects using Grabcad print (with Insight) 1) Voronoi bear: The voronoi bear has missing layers/unattached layer at its bottom everything else seems OK. I do notice a bit of stringing though. Top view of voronoi bear Side view Missing/uattached layers 2) Cylinder with hollow channels: The cylinder has a lot of visible stringing and one of the channels is slightly deformed. Top View Front View stringing Please refer to the attached images.
Please let me know if any additional details are needed.
  • $\begingroup$ Nice post, description and photos. However, what is the question? Could you edit your post and explicitly state a question? $\endgroup$
    Aug 14, 2018 at 9:59
  • $\begingroup$ Can you add print settings, and also list what calibration steps you have performed. $\endgroup$ Aug 15, 2018 at 8:14
  • $\begingroup$ You'll need to fine tune your retraction settings to eliminate (or at least minimize) stringing. What slicer are you using? $\endgroup$ Aug 15, 2018 at 19:09
  • $\begingroup$ Did I miss something, or was the filament material never mentioned? This is a whole different issue with some materials, such as PETG. $\endgroup$
    – Perry Webb
    Oct 1, 2020 at 13:12
I've been able to reduce stringing by reducing the nozzle temp in 2°C increments until it goes away. You'll also want to increase your retraction settings a bit.
The problem is caused by the plastic being too hot and oozing out of the nozzle - it's a bit too runny.
Search Thingiverse for Heat Towers. You'll need to edit the G-code so that your printer adjusts the nozzle temp at each layer. That will give you a really good indication of the best temperature for the given material.
Keep in mind you'll want to print it for each new brand (and sometimes color) of filament.
    $\begingroup$ Good note about different colors from the same manufacturer sometimes having different ideal temperatures. I find that rainbow colors are pretty uniform, but black, white, and silver can vary greatly. $\endgroup$
    – Davo
    Aug 16, 2018 at 13:13
