So apparently the wiring in my home is... questionable. Very rarely, plugging or unplugging things will cause a power dip. This is almost always the result of turning on a fan or something, is only for a moment before coming back, but its long enough to cause my printer to reset. I want to add a backup battery supply using either the 12v cell pulled out of an old apc ups (before the suggestion of just plugging it into that... I did, somethings fried in it and it will ALSO power cycle everything connected to it every few hours) or an old car battery. Is there any reason I shouldn't use this circuit, which was originally intended for amateur radio equipment?
Also is there anything else i should be considering?
