I've got a bracelet concept that I've sketched up as a flat design. I'm trying to found a route by which I can extrude this into a 3d object (depth map?), curve it into a bracelet, then ultimately create a STL file out of it. I'm having trouble finding a way to do this that allows me to "warp" the flat object into a bracelet before I try to print.
Is there a recommend technique for this? I'm not worried about representation of the picture; it's effectively meant to be an 'etched' pattern.
