problem solved by resetting cura.
I have problems like this: How can I fix this? I can't find the right setting.
Also, what are these yellow lines? Do you know how to remove them? They disappear when I disable to show the brim/raft/skirt.
Sign up to join this communityproblem solved by resetting cura.
This problem appears when a face is inverted, so the slicer confuses and expect the other wall to close the object. So you need to reverse that face to show the face out and the back face inside the shape to be filled
I will edit this answer with more examples
I'm pretty sure the yellow lines are showing the full path of the extruder head, including where it's retracted. Somewhere in Cura's maze of menus, there's an option to turn on/off various displays related to the slicing.
As to why the top layer isn't there -- most likely it's too thin in your source model. You might try enabling "Print thin walls" options in the Preferences advanced list. BTW, if you post the original STL or CAD file, we might be able to provide more accurate diagnosis.
