I would like to know if there is any tool/library (preferably python based) that could be used in parsing a Laz file to extract info that is normally found in 3d object files such as vertices. Which could be used to create printable 3d mesh. I already tried Laspy and I could get the x,y,z data from it but it is not a vertices info but rather a scale info. So I would either need a tool to give that or an algorithm for getting vertices from the data from laspy.
    $\begingroup$ It is working @Durodola Opemipo ? $\endgroup$
    – boxsters
    Feb 13, 2020 at 14:30
Given that LAS/LAZ is LiDAR point cloud data, there is a GIS tool called las2tin to convert these files to a triangle based mesh called Triangular irregular networks or TIN by the GIS community. Other GIS tools should be able to do the same, for example ArcGIS.
Once you have the mesh, Google should be able to help you find a way to convert the TIN to an STL. You will need to scale down the STL after creation, as the TIN will probably be at 100% scale.
One example workflow for converting LAS data into an STL is:
  • Using ArcScene: open DEM > convert to TIN > export to VRML
  • Using MeshLab: open VRML > export to STL
  • Using Meshmixer: extrude base > scale to fit standard printing parameters > save as finished STL
More details for the process that I got from Google are available here
