Given a Marlin firmware and a line of G-code such as the following:
G1 F100 X50 Y50 Z0 E-10
What defines the speed at which the stepper motor associated with the E-value is retracting? It is my understanding that the Feed Rate defines the speed of the movement (in this case 100mm/m) but I am not clear how I could accelerate a retraction?
The reason I am asking is that I am not seeing a swift removal of material as i retract. Could the slow feed rate be the issue? I am using a pellet printer (WASP 3MT) and generating G-code from polylines on Silkworm.
