I have designed a bread mark and printed it on the Prusa i3 MK3.
I wanted it to have as sharp edges as possible, so I used a triangle:
However, it seems that the print cut off layers that are too thin (x-y-wise) and instead of a 1 cm high bread mark, I only have 0.5 cm.
What is the X-Y-resolution of the Prusa i3 MK3? In Slic3r, can I make sure that any wall is made as thick as needed for it to be printed?
I have the default 0.4 mm nozzle.
