If you go to the Monoprice website you will find a dedicated page for Ultimaker Cura.
From the page you can read that:
Cura now includes profiles for the MP Select Mini V1 and V2. Go to
“Settings”, “Printer”, “Add Printer…”, “Other”. Select the radio
button next to the printer, then “Add Printer”.
So you must be able to configure it correctly for your printer (this must include the G-code flavor for your printer). Do note that Monoprice does nothing with the Ultimaker Cura installers, they simply link directly to the source at Ultimaker. Also note all the problems related to specific versions and how to fix them.
You write that the:
The control board continues to show the print progress bar continuing.
This I have experiences myself (on a different printer with Marlin 1.1.8), so a non-printing printer while the progressbar progresses. I solved this myself by flashing to a newer firmware version. It appears to be a bug in the firmware.
You might want to explore whether it is feasible for you to update, I read that there are issues with this printer concerning firmware updating (it appears that there are different hardware versions of this printer).
E.g. from this reference:
- If your MPSM V2 currently has Motion Controller v34 or higher
installed then you can update with this firmware.
- If your MPSM V2 currently has Motion Controller v30 or lower, do NOT update with this firmware.
- If you have Motion Controller versions 31, 32, or 33 please
ask before updating with this firmware.
Although the changelog does not mention your problems, you may benefit from a firmware update. Please do this at your own risk, take precautions and read in the matter if your printer is able to be updated. It is best to first look into your settings how the printer is configured in Ultimaker Cura. Preferably, delete the current printer configuration and add a new configuration as described here.
Marlin
,Reprap
is a little different, it uses relative extruder movement from what I can see. Have you updated the firmware recently? Could you add more information. Link to the G-code and to the model? $\endgroup$
