I have a thicker glass plate on the bed. Also, I have a z-axis offset at the maximum value 50 yet the nozzle does not clear the plate.
Why can't I adjust the axis beyond 50?
  • $\begingroup$ Welcome to 3dPrinting.SE! $\endgroup$ Dec 9 '18 at 2:09
    $\begingroup$ mind to show a photo? how thick is your glass sheet? $\endgroup$
    Dec 9 '18 at 4:16
    $\begingroup$ Please explain with a figure what your problem is. The problem is not very "clear". $\endgroup$
    Dec 9 '18 at 8:12
There are several ways to get the Z0 into a position the sotware can account for it without needing to write your own firmware if needed:
  • Remove the build-tak-clone under your glass sheet to get the better heat transfer and remove a couple millimeters.
  • Tighten the bed leveling to account for some millimeters.
  • Move the physical endstop to account for the thicker build platform.
  • $\begingroup$ Moving the endstop switch is what I had to do when I moved to using a glass plate $\endgroup$
    – Kevin
    Feb 1 at 22:29
