This function is called by the g-codes M125 and M600
I could find ADVANCED_PAUSE_FEATURE
defined in configuration_adv.h
and called in Conditionals_post.h
, trice in Marlin.h
, referenced as needed for M600 in Marlin_Main.ccp
and mentioned 2 times.
In Marlin_Main.ccp
it also declares the function pause_print
in line 6482 to 6571. Its start and end are these:
static bool pause_print(const float &retract, const point_t &park_point, const float &unload_length = 0,
const int8_t max_beep_count = 0, const bool show_lcd = false
if (move_away_flag) return false; // already paused
#ifdef ACTION_ON_PAUSE
SERIAL_ECHOLNPGM("//action:" ACTION_ON_PAUSE);
#endif
HOTEND_LOOP()
thermalManager.start_heater_idle_timer(e, nozzle_timeout);
return true;
This function does define the pause state, and relies on the ADVANCED_PAUSE_FEATURE
in some cases. But what calls it? Simple enough, both calls are in the same Marlin_Main.ccp
that defines it. The calls are in the functions that are used for filament change:
gcode_M125
line 8534 (Save current position and move to filament change position)
gcode_M600
line 9939 (Pause for filament change: "M600 X Y Z E L")
