I am trying to get rid of stringing on my prints, to do that I have tried turning on a retraction in Ultimaker Cura, and reducing flow.
When I turn on retraction it causes the extruder to skip on the filament. the extruder pulls the material out as it should, but when it pushes back in as it prints the next parts it goes part of the way then it skips making the bumping sound, it seems to do this almost every time that it retracts.
To stop this from happening I have tried changing the retraction distance from 10mm to 5mm, the retraction speed from 60 mm/s to 40 mm/s, the flow from 100% to 90% and the temperature from 200 °C to 220 °C.
I am using the Ender 3 running Marlin 1.1.9 with an aluminium Bowden extruder upgrade and BLTouch.
How do prevent this skipping due to retraction?
Update:
After changing the setting to what has been suggested in this answer the result of the retraction print resulted in:
It has almost completely solved the stringing problem as well.
