I need to replace this stepper motor with the following product identification:
It’s a Y-axis for CR10-S5 and labeled as JD42HS60-1500A-02F. What type of stepper motor is this?
Sign up to join this communityI need to replace this stepper motor with the following product identification:
This is a NEMA 17 motor. It is virtually identical to the NEMA 17 motors Creality uses in most of their 12V products.
In contrast to other companies, Creality uses a different connector with a flat ribbon cable instead of color-coded wires.
The upper line of the label identifies it more clearly:
Side Note: the Creality Ender3 uses 34mm high stepper motors.
