I recently downloaded Magicavoxel to give this voxel thing a try, and I was curious if there was a way to turn the voxel files into a file for printing?
Magicavoxel doesn't seem to offer a way to export the project as STL.
Sign up to join this communityI recently downloaded Magicavoxel to give this voxel thing a try, and I was curious if there was a way to turn the voxel files into a file for printing?
Magicavoxel supports export as .obj
, natively or with the right plugin.
While .stl
is the standard for 3d-printing exchanges, as it contains a "1-unit" length,(typically that corresponds to 1 mm), .obj
is also accepted by most slicers.
To get to MagicaVoxel's native export, look in the lower right corner, click export and see this pop up:
Press the top-left OBJ
option and you get a save position window where you can store it. Then open it with your slicer and choose a scale - most .obj
files do not contain a scale as the format does not contain a unit measure by default like .stl
and has to be given one.
