My attempted prints on my Creative Ender3 of model: This is the spinning top totem from the movie Inception. https://www.thingiverse.com/thing:23686
The print uses support structures (generated by Ultimaker Cura) failed in the same location twice. It is printed in PLA (1.75 mm) first print at 200 °C, second print at 196 °C.
Failed print 1 Failed print 2
To me, it looks like your G-code induces an incomplete layer of support on the still standing piece, which later down leads to the print failing.
Re-slice the whole thing.
As a matter of fact, I would cut the model in its widest place and print both with the large face flat on the surface and glue the two pieces together after printing. That way I can achieve:
  • no need for support material
  • maximum adhesion
  • no surface problems on the transition from the support to the print
    $\begingroup$ Good advice to print this in 2 pieces, lots of supports are usually a pain for printing as the chances that something goes wrong increases significantly with the increasing amount of support. $\endgroup$
    Dec 30 '18 at 13:25
  • $\begingroup$ Thank you Trish!!! this is exactly the kind of help and wisdom I was looking for. And it lets me know that 3d printing is not some magic press a button process (yet ;-) ) Great answer, and thank you so much!! $\endgroup$
    – hunterp
    Dec 31 '18 at 1:46
