I get an error: printer halted. (kill() called!
Any time I home my machine's X or Y axis. I have just installed a 3D touch auto bed level sensor, ironically it works fine. I was using Sprinter firmware but it doesn't support auto bed level, so thus I'm using Marlin. I am using the latest version of Marlin and it gave me nothing but issues, printer wouldn't move or home at all. I used the latest Marlin 1.1.x bug fix edition (1.1.9) and now everything is working correctly except X and Y homing, the machine throws the error: printer halted. (kill() called!
on Repetier-Host.
When I use the M119
command all endstops (optical, not mechanical) show as open unless triggered, the endstops are working correctly. When I home the X and or Y it will do as it should and stop when it hits the endstop but that is when the errors pop up and the printer freezes/no longer to gives commands without disconnecting and reconnecting to the printer again.
If I home my Z axis it will deploy the probe and come down and touch the bed 2x and no error code and I can still manually move the printer around with the program movements after homing Z axis. I'm not sure what would cause this to happen only on X and Y but any help would be appreciated.
I use Repetier-Host but I downloaded Printrun just to see what would happen and it shows the exact same effect/errors. I also tried the Marlin bugfix 2.0 and it gave the same errors too.
