After a brownout a print failed and it got the whole hotend covered in PLA. I am now in the process of replacing some parts on the hotend (one of the thermistor legs broke of) and also wanted to take the heater cartridge out. The problem is that the bolt that locks the heater cartridge is stuck and I am now afraid to strip the head.
Is there a trick to remove the bolt with the smallest probability of stripping the head? Is it better to apply heat or not? Should I soak it in Acetone or some other solvent? etc.
5 Answers 5
10
Don't Panic!
First of all, a printhead caked in PLA is usually not a death sentence, it is often a temporary setback. Let's start in steps!
Step 1: remove the extruder
We want to work on the hotend, so we remove the extruder feed first. For direct drive, we unload it, then remove it depending on your printer, so the cooling of the hotend remains. For a Bowden, unload and, if possible, remove the Bowden tube from the cooling block. If not disconnect it from the extruder.
Step 2: remove from the carriage
Now that we have the whole hotend assembly bared, we remove it from the carriage. Usually, it is 2 to 3 bolts, more if the cooling solution is mounted separately and has to be removed to access it.
Step 3: remove the cool-end
If you can, remove the cooling fins - we want to have the heatbreak to hold on to.
Step 4: Clamp it up
Take a fire-proof surface (ceramic tile!) and put down the hotend. Rig it up that it can't jump away, best with a small vise. Don't bend the cables!
Step 5: Free the thermosensor
Let's start to clean! If your cartridge still works, get 12V onto the heater and let the stuff melt a little. Use pliers and a scraping tool to clean the thermistor cartridge.
As you have no heat control only heat in short bursts to prevent fire and destroying the cartridge too.
As an alternative and if you can't get the cartridge to work, use a hot air gun or a hot-air soldering station. A soldering iron with a broad tip also works well to scrape off the plastic with controlled heat an as a scraper to remove large chunks. If you use an external heat source, free the heater cartridge first and remove it, hoping that it is not also dead.
As soon as you can, get the thermosensor out. If you run on the heater cartridge, install a fresh Thermosensor, even into the goopy heater block, and wire it to the board to regain temperature control and use the board to provide the power.
Step 6: Finish cleaning
I usually clean up the final stretch (and as far as I can: all steps) under board controlled heat:
Make sure that heater cartridge and thermosensor are installed well and working. Set the hotend to 170 to 180°C and do the last cleaning under the use of regulated temperatre.
Step 7: Do steps 1 to 4 in reverse order.
Reassemble, following the steps backwards.
Step 8: Hot Tighten!
Heat the assembled hotend to 240°C, then tighten the nozzle against the heatbreak to ensure tightness. Let cool, done.
Alternative
Replacement/Upgrade!
One could go down to step 3 and replace the hotend assembly (Heaterblock, Thermosensor, heatbreak, nozzle) with fresh parts and reassemble. This is much more expensive than reusing but cleaner and faster - if you need to print now, you might want to keep one hotend assembly on hand as spare and clean the one replaced while the machine runs.
External heat sources
As mentioned, a hot air gun or soldering iron can provide heat to remove the plastic caking.
The soldering iron has the benefit of doubling as a scraping tool and providing localized heat, allowing to possibly free the thermosensor without unsoldering anything in it, and it won't melt the heater block.
A heat gun provides gentle, overall heating of the beater block, but needs extra care where the hot air is going - it can easily char wood and might remove the solder from the heater cartridge.
A gas torch might be used to burn off any residue on a totally stripped heater block, but it also would be able to melt and deform an aluminium heater block! Do not use it on a still assembled heater block, or it will melt any solder in the heater cartridge and destroy it.
In any case, working on a fireproof surface is mandatory!
Chemically cleaning (for non-PLA)
PLA can be removed chemically, but the solvents are rather nasty and some take quite some time to work. Very toxic dichloromethane was used to make a solution of PLA to create thin layers used in this paper, and most other solvents the study mentions are at least equally nasty. The available working options - ethyl acetate and propylene carbonate - have high price tags associated with them. So chemically cleaning PLA from cheap nozzles is not an economically viable option. However, it is a viable option to use acetone if you have your hotend caked in ABS.
  • $\begingroup$ This is often a great time to upgrade to an extruder with an all-metal hot end, if you haven't already. $\endgroup$ Commented Jan 8, 2019 at 19:10
    $\begingroup$ @JoelCoehoorn An all-metal hotend is not an upgrade, this is a widely spread misconception! It is an alternative, not an upgrade. It would be an upgrade if you want to print materials over 250 ℃ for a prolonged time, mostly used filaments have lower print temperatures. Many problems are associated to all-metal hotends, several questions can be found on this. $\endgroup$
    Commented Jan 10, 2019 at 15:28
    $\begingroup$ Note, that it would be economically viable to save an Olsson Ruby nozzle that costs about 100 €. $\endgroup$
    Commented Sep 12, 2019 at 8:39
    $\begingroup$ Seconding what @0scar said. All-metal hotend will significantly interfere with your ability to get good prints with typical materials, e.g. introducing problems with retraction that might require reducing or disabling it, which in turn results in catastrophic lost/misdeposited material problems. Cooking food in PTFE pans doesn't significantly harm you and printing at 250°C or even slightly above with a PTFE tube near the heat won't either. $\endgroup$ Commented Sep 12, 2019 at 16:33
Acetone will not dissolve PLA, there are other nasty solvents that do that, but it is not recommended to go that way.
You could apply 12 V (if the cartridge is 12 V that is) directly. As the thermistor does not work, you cannot use the printer board. You should take caution not to heat it too far or too hot, but from your experience with your own machine you should know approximately how long it takes to heat up the hotend to working temperature. E.g. start with a minute and try to pry off the lump of plastic with pliers. If you can reach the bolt/worm screw, try heating until you are able to insert the hex key or screw driver.
This video from Josef Prusa shows exactly what you need to do what is described above. The only difference is that you need to connect the heater element directly to the power supply as your thermistor is broken. So don't leave it on too long or you will bake the filament to carbonization, which is much harder to remove. Try to cycle it on/off.
  • $\begingroup$ Actually I soaked the block in acetone and de PLA did not dissolve completely but it disintegrated into an easy to clean compound. So soaking it in acetone actually helps. $\endgroup$
    – E Doe
    Commented Jan 13, 2019 at 8:55
  • $\begingroup$ @EDoe Only for PLA that contains other plastics like ABS. Glad it worked out for you! $\endgroup$
    Commented Jan 13, 2019 at 12:05
I have just gone through this with an E3D v6 Aero hot end.
Working on the hot end while hot is the best way, but using the internal heater is filled with several problems:
  1. The thermister may be broken
  2. The heater may be broken
  3. The electronics of the heating loop (sense, decide, control heater) may be broken
  4. The wires may be too short to make it easy to work on.
It is best to remove the hot end and work on it on your bench -- not inside the printer.
Someone recommended a torch. This is possible, but it is hard to control the heat with a torch. The flame may be hot enough to melt the metals.
Instead, I use a hot air gun. It gets hot enough, but the maximum temperature and the rate of heating is lower. The heat source is more diffuse.
I had an immoveable thermister set screw, which responded well to heat. When reassembling, the heater clamp screw was filled with some plastic which prevented me from clamping the heater while cold. After heating, it screwed in easily.
Don't be afraid to strip the hot end down to the basic parts. Probably you'll be doing it several times over the printer's life, and knowing how to fits together makes everything easier.
If you use a brass heating block (which is a bit heavier than aluminum), you can first use a heat gun to soften the residues to remove the cartridge/sensor.
After removing all electronics, you can use a gas torch and burn the residues off. However, the far best option would be to use a heat block made of stainless steel. I guess heat conductivity is anyway not very important on the hotend as long as the cartridge is powerful enough.
Using a torch makes cleaning very fast. In five minutes you are typically done.
I got a blob of around 5 x 8 cm out of PETG! Setting extruder temp to PETG or even a little higher. I did it all with an older soldering iron. Simply (but carefully!) go with the point into the blob and take it slowly off. With a copper 'toothbrush', I cleaned the extruder and nozzle more times.
After mostly all was down I started with the first layer test (Prusa MK3S+) That was surprisingly almost perfect. Then started to print not very high subjects like rings etc. With that several burned drops came down during printing. Use the 'toothbrush' as many times you can between the first prints!
Done without any damage to the printer as a whole!
