I'm having a problem where every few layers seems to be offset slightly, creating a stepping effect. The images below should be smooth along the sides, but having this ridge type effect. My question is how do I calibrate the printer to print smoothly?
I’m using a Hictop Prusa I3. I’ve recently installed an updated version of Marlin and have been tinkering with the configuration to make it match as close to the original config that was originally installed.
Printer: Prusa I3 (Hictop)
Marlin: 1.1.9
Filament: 1.75 PLA
Slicer: Ultimaker Cura
Layer height: .16 mm
Extruder: 190 °C
Bed: 60 °C
Speed: 30 mm/s
Line width: 0.8 mm
Cooling fan: 30%
Below are a few examples of what I mean by ridges and stepping
    $\begingroup$ Print some calibration cubes and post pictures. $\endgroup$
    Jan 19, 2019 at 7:16
  • $\begingroup$ please try to photograph one of the cubes in a way that we don't get perspective tilt - this can help to identify small layer shifts or oscillation. Also, what is your acceleration and retraction setting? $\endgroup$
    Jan 20, 2019 at 10:35
  • $\begingroup$ Is this printer using a 0.8 mm nozzle? $\endgroup$
    Jan 17, 2021 at 23:32
From the picture, this doesn't look like an X or Y axis problem. I wonder if it is a problem with the Z-axis positioning?
I don't have any specific suggestions, but I would start by, with the printer off and cold, manually turning the Z-axis motor(s) to assure that the movements are smooth and without any binding. If the movement is smooth, then with the printer powered on, try some Z-axis movements, up and down, both listening and feeling for excessive vibration or jerkiness.
What may be happening is that the Z movement is binding for several layers and causing the flexure in the Z-axis to bend upward, permitting some plastic to extrude but forcing it into a wide bulge. When the Z axis finally snaps upward, the build layer is too far below the nozzle, so the plastic does not bulge outward and necks down until it builds a base again. This repeats.
It could be an electrical problem with the Z-axis drive rather than a mechanical sticking or interference, but you will feel that, too, by doing slow Z-axis movements and watching carefully, listening for irregularity, and feeling for any jerk or stutter.
  • $\begingroup$ looks like layer shifting to me... $\endgroup$
    Jan 17, 2021 at 21:30
  • $\begingroup$ @Trish Looks like extreme Z wobble on a low budget/quality printer to me. $\endgroup$
    Jan 17, 2021 at 23:04
  • $\begingroup$ @0scar or that... a real "budget" prusa design $\endgroup$
    Jan 17, 2021 at 23:58
