After uncommenting the REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
, the display is blinking and no characters are shown on the screen, I have already switched the cables between EXP1
and EXP2
, but it did not succeed.
2$\begingroup$ This question could use some more information and pictures. It is a fact that some of the cheap displays have the EXP ports upside down, I have had that myself so I cut out some slots for the notches on the cable connector. $\endgroup$– 0scar ♦Jan 29, 2019 at 23:17
1 Answer
this problem can be solved by turning the slots on the display, as in the image below. Some Chinese displays are inverted from factory.
$\begingroup$ Yes, my experience was the same, I didn't know you could turn the plastic all the way around, good to know for next time! I just cut some extra slots... $\endgroup$– 0scar ♦Jan 30, 2019 at 22:11
2$\begingroup$ I've just switched the slots and it worked like a charm, it made my day! $\endgroup$ Jan 30, 2019 at 22:43
