I have a Monoprice Maker Select Plus, currently using Ultimaker Cura 3.6.0 with the default settings for a Wanhao Duplicator i3 Plus. Right now when a print finishes, the bed retreats towards the back of the machine. I'd rather present the bed forward for easier part removal.
Here is my ending G-Code:
M104 S0 ;extruder heater off G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way M84 ;steppers off G90 ;absolute positioning
It looks like I need to change that G28
line third from the bottom, but I'm not sure what to change it to. I've not yet done any g-code manipulation of my own. I don't know what units it's using, and it looks like it still has relative positioning, so even then I don't know it's a good idea to just set it for the max size of the bed.
So how can I change this code to move the bed as I want?
