This is probably the most basic of questions. When I was shopping for a printer I saw models that would list a slew of certain plastics that the printer can print while other printers (different suppliers) would only list PLA/ABS. At the same time, the instruction manual that came with my printer only listed PLA and ABS.
What is actually used to determine the possible material (other than diameter)? I assume that if the nozzle can reach the required temperature to melt the plastic and the bed can reach the necessary temperature to maintain bed adhesion, then my printer can print that plastic. Am I correct?
For example, my nozzle can reach 250 °C, but the bed can barely reach 80 °C so I can print with ABS but not with ASA (since it needs at least 90 °C on the bed. However, if I switch out the heating element for something beefier then that opens up anything that needs a hotter bed. Right?
Let's assume that I have the means to change nozzles and extruder type to fit the need of the filament. The goal of this question is to limit to one or two limiting factors of the printer without major modification.
