3D printing is often an iterative process and I frequently find myself wanting to re-slice an STL I've already printed, but with just one setting tweaked. The problem is, unless I have left Slic3r open with the STL still loaded, I struggle to remember the exact combination of Print Settings, Filament Settings & Printer Settings I used for a previous print.
Am I missing something, or do I need to be meticulous in manually noting down every single setting? Feels like there should be a way for the computer to handle this for me.
  • $\begingroup$ Did you check the generated gcode? There is a section at the end with the settings used to generate it if thats what you are after. $\endgroup$
    – jkavalik
    Feb 9 '19 at 8:56
