I've been trying to find a 3D printer filament which would not release any chemicals if in contact with heated water for a substantial amount of time. So far, I've easily ruled out both PLA and ABS, as they're not considered food safe from what I can find. I have found PETG filament, which seems to be food safe.
My question is: "Is there's anything special you'd have to do to make sure the print is food safe, or as in my case, to make sure it's safe for usage in a mug?".
I will be using a steel extruder as brass ones may contain lead.
