I've recently acquired a Flashforge Adventurer 3 and am having difficulty printing with ABS. The initial layers seem to lay and stay pretty well, though after a few more moments, one side will peel up from the heated platform. I'd like to know if anyone has optimal and tested temperatures for the use of ABS on my printer for the nozzle and platform?
I've used FlashPrint for slicing my objects using the following options:
- Supports: Disable,
- Raft: enable,
- Resolution: Standard,
- Layer Heights: 0.18 mm,
- First Layer Height: 0.27 mm,
- Perimeter Shells: 2,
- Top Solid Layers: 4,
- Bottom Solid Layers: 3,
- Fill Density: 15 %, Hexagon, Every 2 Layers,
- Print Speed: 60 mm/s,
- Travel Speed: 80 mm/s,
- Extruder: 225 °C,
- Platform: 70 °C,
- Cooling Fan Controls: Automatic,
- Nozzle Dia.: 0.4 mm
