During recalibration of my printer (due to the nozzle catching on the prints), the Z-axis went down where it used to go up, damaging the heatbed steel sheet in the process. It then failed calibration. I didn't change the wiring since previous print although I re-adjusted the PINDA probe. What can I do to fix this?
Answer taken from OP's comment
the issue has been resolved (the PINDA probe was too high)
1$\begingroup$ @helpme - If you care to submit your own actual answer, I will delete this Wiki answer, thanks. $\endgroup$ – Greenonline♦ Apr 14 '19 at 18:35
as an answer (maybe expanding upon it as well, if possible) and mark it as accepted. That way your question will no longer be in the unanswered list. Thanks $\endgroup$ – Greenonline♦ Mar 25 '19 at 14:03
