At the moment the outside surface temperature is around 30 °C. Can I put my PETG spools outside with a fan in order to dry them cheaply?
  • $\begingroup$ Put it in a car parked out in the sun. $\endgroup$
    – Perry Webb
    Sep 24, 2020 at 19:09
The simple answer is: No
There are two basic reasons for this:
  • The sun will not get the filament hot enough to evaporate any moisture which has been absorbed.
  • While sitting out in the sun, it will continue to absorb more moisture, which defeats the purpose.
On Matter Hackers, they give a very reliable way to dry filament:
  1. Preheat your oven to 160-180°F (or 70-80°C).
  2. Place spool in oven for 4-6 hours
  3. Remove and place in an airtight container, preferably with desiccant. 5-gallon buckets with airtight lids from local hardware stores work very well for filament storage. You can use uncooked rice as a cheap desiccant.
Filaments with lower glass transition temperatures (Tg) like PLA, use lower temperatures to dry. Lower temperatures also require more time to thoroughly dry.
That’s really all that’s necessary to dry out your filament and ensure optimum material performance and surface finish.
So if you have some spools that have been sitting out for a while and aren’t printing as well as they used to, dry them out and try again. Chances are they’ll be like new.
You can see in the write-up it states you need to get the oven up to 160-180°F (or 70-80°C). The sun will never provide that level of heat. It also states at lower temps it takes longer to evaporate all of the moisture. Placing the filament into an oven at the proper temps will ensure the best results short of buying a purpose built system like PrintDry which is also mentioned in the article.
    $\begingroup$ the simple answer is correct for most of the way, but there is a way to set up a sun-powered drier for filament... which pretty much comes close to a building a specialized solar cooker. the closed top variant of solar cookers can reach 200°C... $\endgroup$
    Mar 26, 2019 at 18:20
  • $\begingroup$ WARNING Try lower temperatures with your filament first. I put a spool of PETG for 4 hours at 170 and it ended up basically ruining the spool. The filament is melted to itself and breaks apart very easily. I'm lucky to get a strand as long as 10 yards from this spool before having to pause the print because it breaks from being so brittle now. Maybe that's just an issue with the 3dSolutech brand PETG. Better a little "wet" than this $\endgroup$
    – Angelo
    Nov 6, 2020 at 18:11
Here is my suggestion for a cheap, well and temperature accurate drying manner of a filament. I've done it several times for PETG that is actually a very moisture absorbing filament and pops it up when using by ruining the job. Why not using your own printer's heat bed to dry the filament (PETG about 6 hours in 65 degrees of Celsius)? I can guarantee that it works: PETGs Drying On a Heatbed
  • $\begingroup$ Hi Pekka, welcome to 3DP.SE! Although this is a very good proposed method to dry the filament, it actually does not answer the question. Note SE sites are driven by questions and answers, this answer is more something you would post on a forum. Please look into the help center to learn how SE sites work and please take the tour. Thanks! $\endgroup$
    Sep 7, 2019 at 7:48
  • $\begingroup$ Ok, sorry :( I hope you destroy my comment cause I don't know how... $\endgroup$ Sep 8, 2019 at 14:48
  • $\begingroup$ Don't be sorry. :) Please note, the method you propose is very good, it only just not answers the question. If we would have a question how to dry filament without having an oven that can go to to low temperatures, your answer should be great, possibly the accepted answer! $\endgroup$
    Sep 9, 2019 at 6:57
  • $\begingroup$ Good advice! Thanks ;) $\endgroup$ Dec 13, 2019 at 8:06
  • $\begingroup$ @PekkaKoivumäki you didn't do anything wrong. We do allow answers that challenge the premise of the question, i.e. "don't do that, try this instead", as such your answer is perfectly valid, and encouraged. Please don't let the feedback you've had put you off from contributing to the site. $\endgroup$ Apr 12, 2021 at 16:06
