The question is simple - I have a RAMPS 1.4 running Marlin 1.1.9 with the three MOSFETs being used (end, fan, bed), but I'd like to have a couple other Marlin-controlled fans. One of them would be a 4-pin, 6000RPM cooler I got from a dead graphics card. Seeing how it runs perfectly at 12V 350 mA if I keep the control pin disconnected (and ignore the sense pin too, of course), Could I connect 12V and GND directly to the PSU (or RAMPS 12V header) and the CONTROL pin to one of the pwm servo control pins like D11? Or do I need a resistor?
I could add some info about the fan if needed, but it's a FirstD 4-pin, 12V 0.35A fan that can run up to 6000 RPM.
