I've been having trouble uploading the TH3DUF_R2 firmware to my CR-10. I've already successfully flashed the bootloader using my Arduino, but when I try to upload the bootloader I get this error:
avrdude: ser_open(): can't set com-state for "\\.\COM4"
Things I've tried:
  • Changing the usb drivers
  • Changing the baud rate
  • Using a different computers without any other usb devices
My printer is not functional right now with just a bootloader and no firmware, so I'm not really sure where to go from here.
    $\begingroup$ Might be a dumb question but have you checked to make sure you are using the right com port? $\endgroup$ Apr 5, 2019 at 1:34
  • $\begingroup$ And the right baudrate? $\endgroup$
    Apr 5, 2019 at 4:59
  • $\begingroup$ Yeah, I've tried different baud rates, and I'm definitely using the right COM port. $\endgroup$
    – Rhezner
    Apr 7, 2019 at 20:44
  • $\begingroup$ This happens with a busy port, so your card is operating and blocking the communication. I had the same problem two years ago. $\endgroup$ Apr 27, 2019 at 17:19
  • $\begingroup$ Just unplug the arduino, keep all ready to upload (fully compiled) then connect the arduino and just after the sound of detection device of windows click the command upload. This way you don't give the chance to arduino starts to oparate and sature the comunication from usb port. $\endgroup$ Apr 27, 2019 at 17:27
Two possible solutions are given in this thread: Upload error: avrdude: ser_open(): can't set com-state for "\.\COM17"
This post says:
i am able to fix this problem very easily... just press reset button on arduino and unplug from usb and go to the arduino software installation directory (c:/program files/ arduino) and open drivers folder and open dpinst-amd64 by double clicking on it and just install that if it not runs may be your system runs with 32bit and open the file below the previously opened file and install it again.. close arduino programming software and open it again and choose your board and com ports and now it should upload to your board...enjoy...
Or try the solution from this post:
I could fix this problem! Maybe this solution will works for you:
  1. in device manager I had unnistalled the drivers that I had. After reconnect it then it appears in "Other dispositives" with the name "USB 2.0Serial". There are cases that it appears like "FT232RUSB UART".
  2. my serial conversor chip on arduino uno board is "CH340G". Check this on your controller boards because others like "CN480661" has another fix method. If you can't find this chip maybe this video could help you (in spanish, sorry, is where i found the solution): https://www.youtube.com/watch?v=F4ar5sjbZFg
  3. download the drivers "CH341SE" from this url: https://www.dropbox.com/s/3csnhlsbdrznbp3/CH341SER.zip?dl=0 and then decompress it in a folder
  4. in device manager check whether the arduino is shown (reconnect it for that if you didn't do it in `step 1) then do right click -> update software -> browse software in the computer -> examine or browse
  5. Now you have to search the folder in which you decompress the drivers (step 3). After then pulse accept, ignore any advertice and continue. Then it will install the drivers and you will be able to use your arduino.
NOTE: If in this last step windows has an error you need to enable the unknown digital signature installation. check other tutorials for this
These seem to be the only two solutions that worked for other people experiencing the same issue.
Ok... So I found a much simpler answer to this. In my device manager I just right clicked the device (Com port 4, the one that wasn't working for me) and allowed windows to update the drivers from the web.
This fixed my issue. Just wanted to put it out there in case anyone else was struggling
