I am printing on a CR-10 for the first time with white filament1. The problem is it seems that after a certain amount of filament printed one or two layers don't stick to the print which causes a huge gap in the end.
I think the pictures speak for themselves:
Image_1
Image_2
Here is what I already tried:
  • Different print speeds (60 mm/s and 45 mm/s)
  • Different nozzles (both 0.4 mm)
  • Print-temperatures of 200 °C and 205 °C
  • Resliced models in case of faulty .gcode files
  • Support densities of 10 % to 20 %
  • Different models
I tried this with two different models, two print attempts each. The gap occurs earlier in the larger model and at almost the exact same layer on both attempts, same for the smaller model.
The most frustrating thing about this is that it happens a few hours into the print so I can't just sit next to it.
It seems that at a certain layer the filament doesn't stick to the print anymore which causes those straight parts.
I ruled out a faulty z-Rod since the gap occurs at different heights.
I am printing White PLA from Janbex with 60 °C bed temperature. I slice with Cura 4.0 (the linux version).
1 I've been printing for over a year now, it's the first time I use white filament. I don't think that it is entangled filament since the spools from Janbex are always perfectly wound. It did occasionally happen with other filament too though but not this often. I have a theory that it might have something to do with the geometry of the model since there were a few very close hard edges at that height. Maybe the filament didn't have enough time to cool down on those spots. I'm trying to print with lower layer height (0.15 now, 0.2 earlier), maybe that will make a difference...
    $\begingroup$ Is it always at the same height or random? You should look into the friction on the spool or for entangled filament. $\endgroup$
    Commented Apr 13, 2019 at 13:11
  • $\begingroup$ Testing that now. $\endgroup$
    – EVARATE
    Commented Apr 13, 2019 at 16:14
    $\begingroup$ entangled filament will make this happens, however this will be more frequently; if not untangled the strength will tighten the spool until stuck the nozzle carrier. $\endgroup$ Commented Apr 13, 2019 at 16:59
  • $\begingroup$ fwiw, i find white filament needs a higher temp than black, maybe it absorbs less heat in the same time? Try cranking the heat 15deg and see if it helps or melts... $\endgroup$
    – dandavis
    Commented Apr 15, 2019 at 20:59
If the problem occurs at same height I would focus on the Z axis, in particular the gantry and its rollers. Try to remove the Z axis screw and feel if the you can slide the gantry up and down with ease, in particular if it gets harder to slide at roughly the height where the problem occurs. You can use the eccentric nuts to adjust the rollers preload and make it slide smooth. Next on my checklist would be the screw: verify there is no issue on the screw at that height, the Ender 3 is renown for having a Z rod issue due to misalignment between the motor and the nut on the gantry. While writing another idea came to my mind, but I'm sure already checked that: the filament is not clashing or being clamped somewhere when it reaches that height, right? A filament guide would generally exclude that...
