I have an Anet A8 clone printer with a heated aluminum print bed. I'm considering purchasing a glass bed to add on top of the aluminum. When adding a glass bed on top:
- How would I go about installing the glass onto the aluminum bed? Is the major concern here just affixing it?
- How do you adjust for the added thickness of the bed in the printer? Is this just through a limit switch adjustment or something firmware/software related?
- How much do you adjust your heat (if at all)? Does it take a longer warm-up time due to having to heat the glass?
