I obtained the following wire 22 Gauge Stranded Hookup Wire from Radio Shack:
Type/Style: AWM/1007
Wire Gauge: 22 AWG
Insulation Thickness: AVE. 0.42 mm
Rated Voltage: 300V
Temperature Rating: 80°C / 176°F
Use Limitation: Internal wiring of appliances; or where exposed to oil at a temperature not exceeding 60°C or 80°C, whichever is applicable.. Tags may indicate the following: 600V Peak - For Electronic Use Only.
I'd like to be able to hook up RAMPs 1.4 to my switching power supply with this wire. Will this work okay?
