When you updated the print bed, you may have affected either the manual or auto calibration of the bed height and bed leveling.
First layer adhesion is depends critically on an accurate first layer thickness, which depends on the bed height calibration. Adding or, perhaps more critically, removing any bed surface thickness could cause a problem.
With many forms of auto bed calibration, a sensor detects a steel or metallic reference under the surface. The thickness from that reference to the surface of the bed is not automatically detected or compensated. Changing the bed surface, even renewing the surface with another sheet of the same material, may alter the bed thickness enough to affect the adhesion fo the first layer.
If the bed is properly adjusted, the problem may be the surface of the polypropylene. I see that some instructions for cleaning polypropylene build surfaces suggest isopropyl alcohol and/or a mild soap solution. I find that with a PEI build plate, it is sometimes necessary to clean the surface with acetone.
Acetone is superior at removing oils and films from the surface and will do better than multiple isopropanol cleanings. I checked a table of chemical compatibility, and polypropylene is highly compatible with acetone, so a thorough cleaning will not degrade it.
