Following the question I asked here: Replace X axis motor with different model
I have a problem with my new motor. My X-axis is now moved by a 17HS3401S motor, instead of a 42SHD0217-24B motor.
On small segments, like when I need to print an arc with a lot of small straight lines, my printhead "vibrates" instead of having a smooth movement. It seems it stops for a very short amount of time before trying to move again. On longer travels there is no problem.
Do you know if it's because of the motor, or because of something else? (Vref not set properly maybe?)
