What are people's opinions on the most affordable 3D printer with a large print volume, of 200mm x 200mm x 180mm minimum, with a good quality over 100 microns?
  • $\begingroup$ Hi, welcome to the site. We need to make this question more specific for it to be a good fit for the StackExchange format. General opinion or survey questions are discouraged. For example, you could ask "what is the lowest-cost FDM printer with build volume of 300mm cube?" And that would be a better question. (Or whatever details are pertinent to your needs.) $\endgroup$ Apr 10 '16 at 2:11
  • $\begingroup$ @RyanCarlyle is it ok now? $\endgroup$ Apr 10 '16 at 5:44
    $\begingroup$ I think that we should just avoid "recommend me a printer" questions altogether. The answers will always be highly subjective (no matter how specific you state your requirements) and inevitably go out of date (the printer market is rapidly changing). A better question would be "Does printer model X fit my requirements Y?". $\endgroup$ Apr 10 '16 at 7:34
  • $\begingroup$ @TomvanderZanden I'm not saying recommend me a printer I'm trying to see what your opinions are on the best reasonable sized printer $\endgroup$ Apr 10 '16 at 7:37
  • $\begingroup$ "Most affordable" is also too vague. A college student will have a lower reference for affordable, while a professional engineer could have a budget in thousands of dollars. Provide a price range to your question for better results. $\endgroup$
    – fred_dot_u
    Apr 10 '16 at 12:49
