Before you put duplicate from this Which are the food-safe materials and how do I recognize them? please read
I need to know if this 3D Ink™ (PLA Filament) is food safe
Sign up to join this communityBefore you put duplicate from this Which are the food-safe materials and how do I recognize them? please read
In general, PLA is known as a "food safe" filament, especially Natural PLA. However, filament suppliers have different processes that may detriment the food safe quality.
Doing a little digging, I found an article on the M3D site which mentions the following about their filament
All of our products, including our filaments are made from 100% non-toxic components and considered generally safe under normal use. They are not considered a chemical, or a hazardous material by OSHA standards. Therefore, OSHA defines it as an "article" and does not require MSDS sheets. You can see more information about that here: http://www.ilpi.com/msds/faq/partb.html#article
So, without contacting M3D directly to acquire an MSDS (or asking if its food safe), you will not find one online.
Here is an article on a few tips for printing food safe objects as well. In a nut shell, don't 3D print food handling objects with crevasses, using uranium, or intend to put in the oven (a.k.a common sense).
In general no filament is safe as the printing process leaves "nooks and cranies" between the layers where germs can gain a foothold.
For food safe, I would advise:
At that point it it should be dishwasher safe and food safe.
