The first indication for print speed and temperature should be taken from the box the filament comes in. Generally it specifies temperature ranges for the hotend and the heated bed. Sometime, mostly online, more parameters can be found amongst which is the printing speed.
Do note that temperature and printing speed are linked, if you want to print faster you should increase the temperature. But, if you are printing small or thin things you should print slower so that the part cools enough for the next layer. Basically, part cooling is then also important, but not all filament types (e.g. the ones with a high melt temperature like ABS or PETG) like being cooled too much. So you have another parameter to consider.
It is difficult to instruct you to print at a certain speed and certain temperatures as it is highly depending on the filament (e.g. also the filament diameter), the machine type/make and model, extruder setup (direct or Bowden), the print, enclosure, etc.
Because of the many parameters affecting printing, it is usually suggested to calibrate the printer by printing a temperature tower or performing retraction tests to find the print window for your specific setup.
