I printed a case for my phone, a Motorola G4 Plus. I found the model of the casing on Thingiverse
I just downloaded the model, used Meshmixer to check for issues, after that, opened Simplify3d and saved it for printing using an SD Card. The printed size of the model was smaller than expected.
The model designer, says in the description that he used flexible filament. Is it possible than if I change to that filament, the model result is completely different?
Print result - phone casing:
