You may want to use this code to test all the electronics before installing any of the suggested firmwares.
There's a bunch of code in the sketch, and it looks to me like it just makes a component run, or heat up, for a little but and then move on to the next component, and do the same thing is that about right?
Well if I'm testing this out and my printer is already for the most part assembled; should I set the stepper jumpers to something larger like a full turn, or half step, so I can see the motors move? Because I've also read that if you're going to test things out you shouldn't even be hooking up but one of the stepper drivers in case you burn one out!
