I am looking for a away I can convert the horizontal rotation into vertical, typically we use bevel gear for such thing. But I am using a SG90 servo motor for which I am struggling to ger the correct gears to achieve my requirement.
I am not sure is there is any other way I can do this using the SG90 servo motor. I am looking for something which I can 3D print if nothing is readily available.
New contributor
uday8486 is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
put on hold as off-topic by 0scar, Tom van der Zanden, Trish, Greenonline 2 days ago
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "This question does not appear to be about tools and applications of 3D printing, within the scope defined in the help center." – 0scar, Tom van der Zanden, Trish, Greenonline
If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ CV-joints or universal joints can be used also. All depends on your application. This is not a specific 3D printing question, maybe something for Engineering.SE? $\endgroup$ – 0scar May 16 at 12:14
  • $\begingroup$ You can find parametric designs for bevel gears on Thingiverse. $\endgroup$ – Mick May 16 at 12:29
    $\begingroup$ Either, as 0scar states, SE.Engineering or Robotics.SE? I can migrate this question if you would like. Or you could ask two different questions, on here and SE.Robotics, tailoring each question accordingly. For example, ask for a 3D printed part here (if it isn't too opinion based) and asking the SG90 question on SE. Robotics. $\endgroup$ – Greenonline May 16 at 12:40
  • $\begingroup$ Alright thanks, I would ask this on other platforms as suggested. $\endgroup$ – uday8486 2 days ago
    $\begingroup$ Bevel gears are used for exactly this purpose, that is if you can't just change the location/direction of the motor itself. Robotics would be a lot better place to put this question, as @Greenonline suggests. $\endgroup$ – Pᴀᴜʟsᴛᴇʀ2 2 days ago
