I made a simple logo using Inkscape, after saving as an svg file, but when I export that file into Fusion 360 something strange happened.
Multiple times I convert some images (png, svg) to svg file. The process I use is this:
- Scan logo image (scanner or smartphone)
- Open image with Inkscape
- Using the stroke, generate the shape
- All process for generate and save
This process explained above always works for me, when I copy the shape using the stroke in Inkscape.
However, when I was do the process using the shape generator - for example, rectangles, circles, squares, etc. - and export the file into the Fusion 360, it doesn't work.
1 - Inkscape logo
2 - Logo import to Fusion 360
In the example above, the first word does not appear.
