I do not have a clear understanding of what causes resin prints to become brittle. Firstly, it appears excessive cold (in the 40s or even 30s, I am in New England) may be a factor. What else can cause brittleness in resin prints? Is there a difference between resin types?
    $\begingroup$ I consider 30 or 40 unlivable Cold. Some gasses are fluid at that temperatue. But then again, Water freezes at 273.15 and boils at 373.15 Kelvin. Please use SI units! $\endgroup$
    Nov 22, 2020 at 14:37
Many printing resins are inherently brittle.
Brittle is a property of the material - so of the used printing resin.
Look at the first seconds of this video - Punished Props Academy drops an SLA/DLP printed dagger on the ground from about 1 meter and it shatters, despite having been carefully post cured and washed and everything. To mitigate that trouble they did a cast of the item with a different resin.
However, the exact brittle behavior of the print is inherently linked to the exact formulation and thus the exact brand and type of resin used.
Some are less brittle than others - and outright flexible.
You might need to test around, but there are flexible resins. This german essay contains pictures and even a video of a super flexible printing resin. Just an example: One such rubbery resin is Formlabs Flexible 80A, and Matterhackers has a range of different flexible resins. Google does show other brands too by googling "SLA Resin Flexible"
I am not affiliated with Formlabs, Matterhackers, or Techstage.de
disclaimer: I own a company manufacturing 3D printing resins, and all links lead to my products :)
Key reason - resin formula
First of all, it really depends on the composition of your resin. Some of them are more brittle than others. Usually cheaper resins are more brittle.
What causes properties to change?
That being said, some tougher resins even with some flexibility once printed can still become brittle over time. That could happen due to:
  • Continued exposure to UV light. It continues to cure your model and it loses its flexibility. The same goes to over-curing of your prints. If you print with longer exposure time settings than needed it will produce stiffer prints with less flexibility.
  • Arid environment. If the air in your environment is dry, some resins can become more brittle.
  • Cold environment. Heat makes plastics more flexible.
What can you do?
Best way to protect your models from getting brittle - covering them with paint or other UV resistant coating.
You can also choose resins that don't become brittle over time and is less sensitive to above mentioned causes. For example our TGM-7 resin:
    $\begingroup$ Thanks for the disclosure of your affiliation - and hi and welcome to SE.3DP. $\endgroup$
    Jun 7, 2021 at 11:02
