I should mention that this is my experience with Marlin. I can adjust the Z offset all I want in the UI, but not the X/Y offset. If you reinstall the probe, I've heard you may need to adjust the Z offset (makes sense, you might not mount in the exact same way). I assume X/Y offsets get affected as well, so it doesn't make much sense to me that you'd have to rebuild the firmware to adjust those values. Maybe they're less sensitive to change? Anyways, not sure what makes them special enough to exclude from the UI.
My printer seems to work okay using a prebuilt firmware, though it could just as easily be pointlessly leveling 50 mm off of the nozzle for all I know.
  1. Usually you install the sensor once and keep it unchanged for years. Nozzle, though, is an element people, depending on printer usage, replace semi-frequently and the Z offset will change with different nozzles, different tightness, etc.
  2. XY probe offset has very little importance - your bed level changes very little over distances of order of 1 cm, so 1 cm of error in XY probe offset is negligible. Meanwhile, even 0.05 mm Z offset difference impacts first-layer adhesion significantly.
On a separate note, you don't need to rebuild the firmware to change the probe offset. You just need an interface (USB cable) and terminal (Pronterface) that allows you to communicate with the printer using G-code. First issue M501 to load the configuration from EEPROM, then M851 with the right X, Y values to set the XY offset, then M500 to save the changes to the config to EEPROM. No firmware update is needed.
