At office we have a hidden WiFi network. I'm not able to connect our Dremel 3D45 to this network, since when you tap on "WiFi" it scans for the available networks and it does not add the "Hidden network" item as usual.
I also tried to make the network visible for a while. Then I connected the 3D printer, but as soon as the network hides the SSID (even without bringing down the AP) the printer disconnects immediately.
Was anyone able to connect to a hidden network on Dremel 3D45?
Unfortunately, I cannot ask the IT to change this settings permanently.
