I've just added a Z-Probe sensor to my custom printer (Arduino
- RAMPS 1.4
- Marlin 2
default disabled EEPROM) but now I'm confused. Printer seems to work but I cannot configure the right nozzle height.
I use Pronterface
and before start printing I send G29
code. Printer succesfully ends bed calibration. At this point I start printing but the printer seems to ignore the calibration (no bed compensation).
Do I need to run other commands to tell printer to use the previous calibration?
G29
activates theM420
to enable the grid. AG28
after will reset this. Did you set the correct trigger point to nozzle offset withM851
? Please do elaborate onseems to ignore the calibration
: is it incorrect distance setup or is it ignoring the complete grid? $\endgroup$G29
returns all the grid values (Ex.: +0.03 +0.01 -0.01 ...) and in my mind I expect Z-axis will compensate those values moving the nozzle high or low during layer print. The Z-axis instead never moves. $\endgroup$G28
is called afterG29
, this disables bed leveling. $\endgroup$
