I have OctoPrint set up on a Raspberry Pi (OctoPi). I have loaded a number of G-code files to the SD card on the printer.
My question is: If I initiate a print from the SD card via OctoPrint, can I then turn off the RPi so I can use it for other things while the print continues?
Your printer will stop printing. So no.
Disconnecting the USB or connecting it triggers a reboot in the printer. As a result, you can not disconnect or turn off the print server running OctoPrint.
