I'm trying to figure out how to get my BTT Smart Filament sensor to work with my printer.
I have looked at Getting BTT filament sensor to work and have tried almost everything they did.
Relevant Specs about my printer:
- Ender 3 (not pro or v2)
- BIGTREETECH SKR Mini E3 V3
- BIGTREETECH TFT35 E3 V3.0.1
- Sensor plugged into
E0-Stop
on the SKR Mini. - Running latest version of Marlin bugfix 2.1.x (last commit 12/5/2022 12:01:08 EST)
- FYI I also do have OctoPrint running and connected to the USB port of the SKR (not sure this matters).
When I follow BIGTREETECH setup instructions and several youtube videos for setting up configuration.h
and configuration_adv.h
, build the firmware, flash it on the board. It always starts the print, then immediately stops and reports "Filament out". I've tried setting the following options:
configuration.h
options:
#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
#define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 >followed by M500.
#define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a >FIL_RUNOUT#_PIN for each.
#define FIL_RUNOUT_STATE HIGH // Pin state indicating that filament is NOT present.
#define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins.
#define FILAMENT_RUNOUT_SCRIPT "M600"
#define FILAMENT_RUNOUT_DISTANCE_MM 10
#ifdef FILAMENT_RUNOUT_DISTANCE_MM
#define FILAMENT_MOTION_SENSOR
#endif
#endif
I've tried flipping
to
#define FIL_RUNOUT_STATE LOW
but it behaves the same.
Anybody have any ideas? Did I miss something?
