I'm probably going to answer my own question because I ordered a set of ball bearings to repair the extruder and then walked passed my lathe and realised all I had to do was turn some brass bushes the same 10 mm OD and 6 mm ID to replace the ball bearings. Thirty minutes later the printer was back online.
Now thinking about it, I wonder why ball bearings are used. There is no critical clearance between the filament and the drive cog as the filament is spring-loaded against the drive. Thus as the bearing wears a little over time it's only a matter of increasing the tension. There would be no sudden collapse in the middle of a print job. Of course, there might be good reason to once every 100 operational hours to re-grease the bearings. There would be plenty of warning of impending drive failure and plenty of time to figure in a new bearing. I expect however the brass bush to last the lifetime of the printer.
Has anyone been down this path with any sort of success?
Standard parts.
The idler wheels of an extruder are all standard parts. While a bushing is a suitable replacement for a ball bearing in the specific application, the bearing has some benefits over it:
  • Mass availability. Buying them in bulk is cheap for the manufacturer.
  • Harder to seize up the mechanism. A ball bearing that is slightly out of spec (e.g. too tall central boss) will not block up the mechanism for the inside and outside of the bearing are decoupled.
  • More compatible with screws. Unless the bearing is seized up, the screw that goes through the part does not need to be smooth but can be threaded everywhere - so the bolt is a cheaper standard part than one with a straight shaft for a bushing.
