9
I am new to 3D printing. I thought that the black surface of my print bed was supposed to keep things stuck without additional tape, spray, etc. However, every time I print something, this same corner, and only this corner, detaches.
Any advice on how to fix this?
  • Monoprice Makerselect V2
  • Hatchbox PLA
  • Temp 195/50
Photo of print warping in corner
This is very likely caused by an uneven bed. It's probably lower in that particular corner: the nozzle is further from the bed, so the filament isn't squished down as much and therefore releases more easily from the bed.
Your bed should have 3 or 4 screws that you can adjust, you should loosen the screw in the corner that is giving you trouble.
  • $\begingroup$ That seems to be the problem. The print bed has a significantly low spot in that area. thanks. $\endgroup$
    – beater
    Dec 1 '16 at 14:06
  • $\begingroup$ I'm paranoid, so I often overtape the brim to ensure it doesn't come loose. You might also consider raising the head temp a bit so the first layer is less viscous and will microflow onto the bed better (more adhesion) $\endgroup$ Dec 1 '16 at 15:27
  • $\begingroup$ After trying to deal with this for a while I realized aluminum warps with heat and the print surface will never be flat. I use a glass plate now and it is much better. $\endgroup$
    – beater
    Aug 1 '17 at 12:17
