So there is a company called impossible objects that use CBAM technology witch the description can be found here http://impossible-objects.com/technology/ I am pretty sure that they are the only ones using this process, I want to know why. CBAM makes stronger material out of carbon fiber in a very sophisticated process stronger than FDM(Fused Deposition Modeling). This is interesting and I want to know why. I understand the process but not the pros and cons.
1 Answer
Well the CBAM stuff is SUPER new, requires a lot more work done by hand (currently), and is going to be WAY expensive compared to widely used FDM machines.
Seems to me like a carbon fiber mixed filament is a cheaper way to go, with a possible annealing process to get the tensile strength up post-print.
Try locating a CBAM printer for $200! Maybe if the process becomes quicker, and the machines/materials cheaper to purchase, we could be using this method more in the future. I feel that we will likely advance the materials we have with FDM much faster than this other process would catch on and become affordable.
