I have just bought my own 3D printer. However, I am now reading that there may be some safety risks to 3D printing. I will be taking some precautions, such as buying an enclosed 3D printer (the FlashForge Adventurer 3), using PLA instead of ABS, and putting my 3D printer in my garage. However, I am still concerned about the possible risks. What are some other good safety tips and best practices when 3D printing? Am I doing enough, or should I do more? What have other users of 3D printers done to mitigate potential safety issues? Please let me know.
    $\begingroup$ You'll want to narrow down your question, as broad spectrum requests are not supported in SE. $\endgroup$
    – fred_dot_u
    Mar 17, 2021 at 21:22
    $\begingroup$ They are usuallly at the beginning of the user manual. $\endgroup$
    – Perry Webb
    Mar 18, 2021 at 11:51
  • $\begingroup$ Starts on page 3: e3printable.no/upload_dir/shop/Flashforge/Adventurer-3/… $\endgroup$
    – Perry Webb
    Mar 18, 2021 at 11:58
  • 4
    $\begingroup$ Are you talking about personal safety, like burns from touching the hot end or getting your fingers pinched, or hoping to prevent/mitigate your printer bursting into flames? $\endgroup$
    – Caleb
    Mar 18, 2021 at 16:27
  • $\begingroup$ @Caleb I am wondering about the potential for toxic fumes or ultra-fine particles being released. $\endgroup$
    – shwin320
    Mar 18, 2021 at 22:07
5 Answers 5
Check where the moving cables (especially for the heaters) are bending. The bending radiuses should be as wide as possible and connections or soldering points should never see any direct force from movement. Add a strain reliev if there are any such connenctions to prevent them from failing over time and possibly melting down.
There are several ways to be injured with a 3D printer. The biggest threats come from the printer running under normal conditions. The uncommon, exceptional, and difficult to quantify threats come from fire and fumes.
For fire, consider the 3D printer to be like any other 400W heating appliance in your house, with the advantage compared to, say, a television in that you can inspect most of the failure points.
Check the feed points where the power connects to the power supply, main board, and the power lines to the bed heater and hot-end heater cartridge. After a few hours of printing, these should still not be hot.
There is always the possibility of a thermistor failure and thermal run-away. Most good control firmware should detect this possibility and fail with an error. If you are using custom firmware, you might want to check that this is included.
For fumes, the evidence is real that fumes are produced. It is less clear the nature and dosage of their effects. If the fumes bother you, don't breath them. If you are concerned, consider an enclosure with an activated carbon filter.
For the more immediate threats, you need to always take care when working with the printer. The hot end can burn you quickly. The heated bed can burn you more slowly. Gears, belts, and moving parts cause pinching hazards, and blood blisters can be raised easily.
Glass beds may have sharp edges, and can break to create thousands of sharp edges.
In conclusion, remember that stamped sheet metal parts, present on some printers, can bear burrs and sharp edges, inviting you to leave bloody finger prints.
A 3D printer, like many things, is dangerous in many ways. I've experienced the common threats, and have avoided the less common ones.
Be careful, but in my view a personal 3D printer is by far safer than any metalworking machine. I have been more injured by a drill press, and welding fumes are more noxious then filament out-gassing.
Technically, you should never leave your printer running unattended. Printer fires are rare, but it can happen, especially with cheap printers with poor quality control. Personally, I would just make sure that there is a fire alarm near by, so you'd be alerted if there was a fire.
Also, the fumes concern is valid in the sense that you don't want to sleep in the same room as your 3D printer. The following article points out that if you are spending time in the same room without proper ventilation you'd benefit from potentially using an enclosure with a HEPA filter. Also, the article points out that using PLA may be a safer choice than other materials such as ABS or Polycarbonate when it comes to harmful particles: https://3dinsider.com/3d-printer-fumes/
    $\begingroup$ Welcome to 3D Printing SE and thank you for your contribution. It would be appreciated if you could summarize the article in case the link ever goes dead. This way others that have a similar question can at least get the gist of the article. $\endgroup$
    – agarza
    Apr 30, 2021 at 3:33
Install an overhead vent, like those you would have above your stove, to direct fumes and micro-filaments away from the area. You could alternatively use a box fan with a thin air filter attached to it, but the idea is to draw those fumes away from the room.
Assuming you are using PLA filament, it is plant-based and very safe. The reason some 3D printers have enclosures is becasue it helps keep some materials warm, its not for safety and especially not for fumes. You could run the thing in your bedroom 24/7 and I guarantee you would be plenty safe.
  • $\begingroup$ ABS is actually pretty toxic when heated. The encloure has a double function in that case. $\endgroup$
    – Hacky
    Apr 30, 2021 at 7:15
    $\begingroup$ I guess it would help a little then, I'm just saying PLA is very safe and most likely the only thing he/she will be printing, and it's not necessarily what the enclosures are designed for. $\endgroup$
    – Randomaker
    Apr 30, 2021 at 16:50
  • $\begingroup$ PLA may also contain additions we are not aware of. I believe especially cheap and undocumented. Where is colour came from? I can often smell the difference, though obviously I cannot say what is a chemical reason. I would not use the cheap one as food safe, for example. $\endgroup$
    – octopus8
    May 2, 2021 at 7:29
  • $\begingroup$ @octopus No, it is definitely not food safe. Yes you're right it could have something slightly toxic in it, but if no one has figured out that it's unsafe in the many years we have been using it, it should be pretty safe. $\endgroup$
    – Randomaker
    May 2, 2021 at 19:42
