I’ve a Flashforge Adventurer 3 which I’ve found to be a fantastic out of the box ready to go printer. I’ve clocked up 500 hours on it.
I’ve had issues where the nozzle was too close to the print bed, making it impossible for the extruder wheel to force filament down the bowden tube. With harder filaments that results in clicking as it’s cog is skipping. With softer, usually matte PLA it’s just wearing a groove and no longer pushing. I have to take the then baked filament and manually push it out of the nozzle, then bed recalibration.
I have a filament dryer, and use it every time I’m printing as it’s a perfect dispenser with it’s roller bearings.
I recently keep getting prints where they start out perfect, but then after about layer 10, the extrusion simply stops. The printer obviously carries on like all is ok, but there’s not even spaghetti.
What could this be? Do I just need a new nozzle? I don’t understand how a metal nozzle printing plastic can deteriorate it. It’s not the same as pitting you get in a soldering iron tip surely…
